Part Number: LP5036
My customer is using the LP5036 and want to know - If the Vcc pin is unpowered and the LEDs still have 5 Volts on them, is there a possibility that the LED supply will back feed to Vcc and other pins of the chip?
Viktorija
Part Number: LP5036
Viktorija
Hi Viktorija,
Each channel is supposed to be high impedance when Vcc is off.
Thank you for a quick reply. Is there anything we mention about this in the datasheet/other documentation, I could direct customer to?
