Other Parts Discussed in Thread: TPS61021A
Hi Team,
Can you recommend a boost?(1.5-1.6Vin, 3.8Vout and current is 1A, peak current may be 2A.)
I think TPS61022 is ok? Or have other better choice?
Hi Amelie,
TPS61022 needs a minimum 1.8V input startup voltage. So it cannot work at 1.5-1.6Vin.
If load current is 1A, TPS61021A would work for this application. But it cannot output 2A current continuously.
May I know where does the input voltage comes from? How long does the peak current last and load current transient speed?
