Hi Team,
My customer used LM5160 as fly-buck controller, and reported several issues for startup/overcurrent/Cbst drop down issue.
The system setting is list as blow:
-- Input range: 15~18V[typical 16.5V];
--Primary output: 7V @ no load;
--Secondary Output: 24V@0.13A
and reported below issues:
-- Output couldn't build while startup with no load or light load?
--Input Current >4A before the EN/UVLO voltage <1.24V;
--Bootstrap capacitor dropped down for a while;
More details could be found in attached file.5554.E2E.docx
Could you kindly help on below items?
Could you kindly review the schematic and the parameters setting, and give comments on startup/overcurrent/Cbst drop down issue?
For start-up issue, could you kindly give comments why the no load/light load may not build correctly output?
While using LM5160 as fly-buck controller, the Primary-side output should less than ½ of input minimum, the general understanding is for helping minimize the secondary peak current and improving load regulation, could you kindly share more information?
