HELLO,
CAN I USE LM3481 FOR BOOST CONVERTER WITH FOLLOWING SPECIFICATIONS,
I/P VOLTAGE-12VDC
O/P VOLTAGE-24VDC
O/P CURRENT-5A
HELLO,
I/P VOLTAGE-12VDC
O/P VOLTAGE-24VDC
O/P CURRENT-5A
Hi Payal Valve,
Thank you for your interest in LM3481.
Yes, you should be able to consider LM3481. However, please see datasheet and application notes for details such as supply range and switching frequency. Note the frequency range of LM3481 is 100kHz ~ 1MHz.
Yinsong
