TPS65950 - Internal Devices Power Consumption
Other Parts Discussed in Thread: TPS65950
Champs,
TPS65950 Power Providers table on datasheet talks about Internal LDO's Maximum current capability. Is there a way to find out the Typical internal current consumption of USB, RTC, ANA1, ANA2 for different operating modes?
  • Hi Selva,
    RTC consumption is in few uA range. Also this is true when in back up mode. In normal operation mode the RTC is supplied by VBAT as this is a valid source.
    It is difficult to give typical values for others as it depends on the mode (active, sleep) and also which sections of the module are active.
    I hope this helps.
