LM73606-Q1: about SYNC/MODE pin
Part Number: LM73606-Q1
Other Parts Discussed in Thread: LM73606
Hi TI,
I want to know the behavior for SYNC/MODE pin of LM73606.
I see that I can use MODE pin to select auto or FPWM mode. Can I change the mode while power supply is operating? For example, during idle I want low standby current, so set MODE to auto; while operation like GSM calling, switch to FPWM mode for better performance.
The further complex case is that when I use external clock on SYNC/MODE pin, and the clock fails at high or low, what's the converter's mode now? Will the converter's mode (auto or FPWM) still based on MODE pin voltage?
Thank you and have a nice holiday.
