page 38-39 of the SLUUAQ3 tells that operationstatus[SLPAD] and operationstatus[SLPCC] are '1' when the device measures voltage ,temp. and current during sleep mode.
if operationstatus[ SLEEPM] is '1' , does it mean that the bq4050 is on SLEEP mode?
HOWEVER, the exit condition to NORMAL MODE is SMB command recieved , and in order to read the operationstatus bit , i should send a command ,thus for sure the device will exit sleep mode and as i understand, i cannot check if the device is working on sleep mode, where is my mistake ?
what is the correct method to make sure that the device is working on "SLEEP MODE"?
thank you very much.
Victor
