Hi Sir
May we connect CHG pin to MCU I/O pin and detect it high/low?
if yes, how to connect it? (is direct add pull high resistor to vcc or??)
Bogey
Hi Sir
Bogey
Hi Bogey,
Since the /CHG pin is an open drain configuration, you can certainly tie the pin to an MCU. You will need a pull-up resistor from /CHG pin to MCU VCC (or IO supply) in order to be able to detect a high or a low.
Let us know if you have any questions.
Gautham
