Hi all,
I would like to know how to select the suitable size of BQ24133 Rin / Cin.
Do you have related document of select the snubber value and size? Thanks.
Roy
Hi Roy,
Unfortunately, I do not. The recommended value in the datasheet is used across several of our higher input voltage products. If you want to test the RC filter's effectiveness, you can measure the voltage overshoot at plug in. As long as there is little to no ringing at plug in, the filter is sized properly.
Jeff
