I am reaching out for TPS53626 application. I want to know how to adjust DC gian to get better load regulaton. If anything is confidential, you can reply to jimmy-zhou@ti.com. Thanks!
Best regards!
jimmy-zhouti.com.peter
Best regards!
Hi Jimmy, Can you share the result you measured? Can you also post the schematic? There are reference designs existing for this device which intentionally add a "load line," (referred to as Droop in the documentation) to make the output voltage position itself based on the load curretn.
