Other Parts Discussed in Thread: BQ24650
Hi Team,
Could you please confirm if BQ24450 is the best solution for below requirements? Thank you.
1. DC Vin = 14V
2. Charge power as 12V/1A
3. Used for 12V/6.5Ah Lead-acid batteries
Kane
Hello Kane
The BQ24450 is a linear charger and will work well with smaller battery, lower charge currents and voltage. At higher charge currents and voltages the power dissipation on the pass transistor becomes excessive.
A better solution would be a switching charger such as BQ24650 it can be adapted for Lead acid Batteries. See application note SLVA437A.
