Other Parts Discussed in Thread: TPS23755
Hello!
Please advise how to make a project on a TPS23758RJJ chip with an output voltage of 12V? I did not find examples of such schemes.
Regards, Serg.
Hello Sergey,
So the TPS23758 is designed to be used with a synchronous flyback, and we found that topology is optimized for 5V.
If you need 12V, I suggest using our TPS23755. It uses diode rectified flyback topology instead, which we found to be optimized at 12V.
The EVM is 12V: http://www.ti.com/tool/TPS23755EVM-894
If this post answers your question, please indicate so by marking this thread as resolved. Thank you.
Michael P.
Applications Engineer
Texas Instruments
