Other Parts Discussed in Thread: TPS2595
A customer wants to use the TPS25921A and the TPS2595 (in seperate subcircuits, voltage levels are still unknown) and in the design it is still possible for reverse current to occur. However, no significant design changes are unfortunately possible and the TPS25921A and TPS2595 both lack something like the BFET port as in the TPS25924x.
Therefore large changes/options such as using load switches and dual FET solutions are not possible to implement. Are there any ways to ensure there will be no reverse current(or atleast avoid it) by setting up certain component values (criteria)?
Both will be used in a very similar way like the simplified schematic of the datasheets:
For example, one possible option is Cin >> Cout. Are there any other recommendations similar to this? Or any other minor solutions if there are any are much appreciated.
Thank you.
Assad
