TLV743P: Question about the enable pin
Part Number: TLV743P
Hi team,
My customer use TLV743P device to get 1.8V output power, and MCU control signal is used to control the enable pin, together with other two enable devices. However, After power-up, the enable signal decrease from 2.4V to 1.2V. And when remove the TLV743P device, the enable signal would keep 2.4V(other two enable devices are still on board). What's the maximum enable current? Any possible cause for this issue? Thanks!
Best Regards
Zhengquan Lu
