Reviewing other forum posts in regards to the STAT1/STAT2 value when in IDISCHG:
BQ24610: State machine leads to STAT1 flashing if there is resistance in the charge path
"When the battery is almost full, STAT1 often begins to switch its attached LED on an off, leading a user to believe there is an error (a flashing red LED)."
To clarify: is this a fault in the board design or how the BQ24610 chip reacts in the Idischg state - STAT1 is OFF, therefore the STAT1/STAT2 state is OFF/OFF which seems like a Fault indication?
Do you have an estimate on when the documentation will be updated with this information and also with the fix to the Battery detection flowchart?
Thanks for your help.
