We are using BQ24650 MPPT Charge controller in solar street light project. Till 1.6A charging current there was no heating problem. When charging current is set at 5A (by changing sense resistor, inductor and capacitor values).All functional features are working fine. But Charge controller chip and PCB is getting heated up. We have provided sufficient grounding as per BQ24650 application note.
We have provided charge controller under neath via's as per the recommendations and also provided heat sink in bottom side of the PCB (4 Layer PCB).
Charging voltage is from solar panel (12V panel), MPPT value is set at 17.5V
But heating issue is not solved
Please suggest us how to solve heating issue
