can someone explaine me why the IC is closing the mosfet only on first pulse? it should close when
vin-vout >250mv correct?
if you measure on the 2nd pulse there are 500mv so this means the mosfet is not closed and also st pin remains low.
if i change the load to 7.2OHm then it seems to work properly
thank you
