Other Parts Discussed in Thread: TS5USBC41,
Dear TI support,
we're trying to incorporate the BQ25898D into a portable product which makes use of USB type C (DRP). Since both charger and processor need access to the USB data lines, we use the TS5USBC41 to switch between these devices. In our current design is VBUS applied delayed because the USB type C controller performs a handshake initially.
Will it pose a problem when the data lines are connected before VBUS? We assumed for now it's unsafe and therefore added two N-channel MOSFETs to control the output enable pin on the mux only when VBUS is already applied or when the system is running in host mode.
Thanks in advance for your support.
Alex
