I've successfully measured and processed the data for GPC, and received the report by email.
In the "GPC_CEDV.txt" file from this report I've found 2 things that I don't fully understand:
- The following sentence: "If EDVV bit is set to 1, EMF and EDVR0 have to be multiplied by the number of serial cells when written to data flash". I cannot find the EDVV bit. Neither the EDV_pack parameter mentioned in this thread: https://e2e.ti.com/support/power-management/f/196/t/800233?BQ4050-where-is-EDVV-bit-
Where can I find the "CEDV gauging configuration"? - I received the following CEDV parameters:
EMF
EDVC0
EDVC1
EDVR1
EDVR0
EDVT0
EDVTC
VOC75
VOC50
VOC25
In bqstudio I can find the location to enter the top 7 parameters in Data Memory --> Fuel Gauging --> CEDV cfg. I can't find a location to enter the bottom 3 parameters (VOC 75/50/25). Where should they be entered?
I hope you can answer my questions. Thank you in advance.
Kind regards,
Niels
