Can the output voltage of tps61088 be changed by using DAC to control FB.The following is the schematic diagram I designed. I want to control the output voltage of tps61088 from 0V to 12V through the DAC output of single chip microcomputer. Help me to see the schematic diagram which needs to be modified to realize the output voltage adjustable from 0V to 12V, thank you!
