Hi team,
I have a customer wanted to evaluate our TPS22990 for their server application. however, they are looking at lower Rds_on solution and wondering if we could parallel 2 or 3 TPS22990 together to reduce the effective Rds_on.
what will be the consideration they need to take care for parallel operation? (could just use the same CT valur, or need to connect all the CT pin together?)
Or it is not recommended for parallel operation and should consider external FET solution (hotswap, TPS247xx)?
SK Loo
