Hi team, working with a customer on this device. Using it for a POL boost from 9V rail to a 15V output.
Is it ok to tie VCC and VIN together to save some power dissipation?
Datasheet is section 7.3.1 states that the body diode of the internal MOSFET should never be forward biased. So, wanted to check if tying these pins together could cause a device reliability issue.
Thanks in advance!
