Part Number: BQ24773
Other Parts Discussed in Thread: BQ28Z610,
Hello TI,
I design charger and battery management system for Khadas 3 by using BQ24773 and bq28z610. It will be 12V/3A input, 1S/6A (20A*h) output charger.
And I try to use simpler schematic than that given in datasheet and EVM.
- I no need Input Current Monitor (ACN and ACP pins join together and connect to Vin).
- Also I reduce BAT current sensing resistor to 2mOhm.
- I no need BATFET cause I use outside MOSFET drived by MCU.
Will BQ24773 work correct in this schematic?
Thank you.
