BQ24105-Q1: cell balance
Part Number: BQ24105-Q1
Hi TI-team
The customer configuration is going to use 3 cells.
Is cell balance monitoring necessary ?
Koji Hayashi
  • Hi Hayashi-san,
    That is a system/application level decision.  Cell balancing keeps all of the series batteries at a higher capacity for a longer lifetime (i.e. more recharge cycles).  If the system doesn't require the batteries to be frequently discharged and recharged (e.g. battery backup) and/or cost to replace the expired batteries is low then cell balancing is likely not needed.
    Jeff
  • Hi Jeff-san
    Thank you for response.
    I understand.
    Koji Hayashi
