Dears,
If TPS54618 EVM VIN is floating, then TPS54618 VIN will occur 8V when apply 4V at VOUT.
Could you explain the boost back issue? And how can we prevent boost back?
thanks.
Dears,
thanks.
This phenomenon is well explained in the below paper, topic 6: Prohibit the boost mode of step-down converters
http://www.ti.com/lit/an/slyt689/slyt689.pdf
If you have any other questions, please ask.
Thank you very much!
Dorian
Hello Dorian,
Thank you for your answer. I will read the paper and come back to you if any questions.
thanks.
Did you implement a viable solution to prevent it from happening such as disabling the part when applying 4V at VOUT if VIN is floating?
Do you have any further questions?
Dorian
Hello Dorian,
Since EN pin already connected to VIN, so we add a diode at the output to prevent reverse.
Thanks.
