The fuel-gauge/protection IC we are using is a bq28z610. We wish to automate our factory End of Line testing and haven't been able to locate recommendations in regards to "Calibration" during each stage of production. For example we will have a PCB level End of Line test as well as a Final Battery Pack assembly End of Line test.
Calibrate voltage (Only needed at PCB level?)
Calibrate temperature (Only needed at PCB level?)
Calibrate Current (Should this be executed at both test stations; or for certain after the cells a attached)
etc.
