TPS57160-Q1: LTSpice simulation doesn't finish..
Part Number: TPS57160-Q1
Other Parts Discussed in Thread: TINA-TI
I have tried importing the PSpice model of TPS57160-Q1 into LTspice, since I had some problems simulating the device in Webench(see other posts). However, there is a problem with the simulation. It ends up running extremely slow and I never seem to be able to finish the simulation, since the speed slows down immensely.. I tried both the encrypted and the unencrypted models, but neither work.
Does anyone have a working LTspice simulation of the device?
I have attached a simulation of the example in the datasheet(figure 51). Please let me know if you spot any mistakes or issues. Will it run on your machines?tps57160_trans.zip
