BQ40Z50-R1: discharge fet closed as default
Part Number: BQ40Z50-R1
I had a question about the BQ40z50-R1. When BQ40Z50-R1 exits from shutdown mode by applying power to B+/B- terminals (fyi, no power applied on P+), the Discharge FET is open at default (DSG pin in low at default). FG keeps the status until there is any power applied to P+ terminal. My question is, is there any firmware or parameter change possible to put the Discharge FET to close (DSG to be enabled to drive Discharge FET)? Is there any way to put discharge FET close at default?
Thanks for the help!
Adam
