TL783: Too little amperage
Part Number: TL783
Is there an alternative to this controller that can handle 1100mah?
  • Hi C,
    We have many other voltage regulator options in TI that feature larger current capabilities. In order to suggest an appropriate device, we would need to know your operating conditions.
    What is the input voltage needed to be regulated? What is the output voltage needed? You mentioned 1100mAH is this 1.1A a continuous output or maximum peak output?
    With this information we should be able to find an appropriate solution.
