Part Number: BQ25895M
Other Parts Discussed in Thread: BQ25616
Hi Team,
my customer is using BQ25895M as solution and have below 2 questions,
1. how to change charging current ? can it done by HW(hardware) setting?
per my check , the device's charging current can change through I2C, but not hardware setting,
since there's no pin for change the charge current.
charging current set (REG04) by I2C
2.what's the default charging current?
per d/s , the default mode charging current is 2.048A , and pre-charge current is 128mA.
please kindly help to check if my understanding is correct, thanks!
Andy
