Hi Expert,
I saw that maximum -1V show in output voltage to ground(steady state), could you help check it correct or not?
Mark
Hi Expert,
Mark
Hi Mark,
There is nothing in the device history to suggest it is incorrect. These devices are tested in open-loop so it is the pin that handle up to -1V steady state. If you are interested in an inverting topology, the datasheet has an example in the applications section.
Thank you,
Ethan
