Other Parts Discussed in Thread: TLV61046A, TLV61046, TPS61093
Hi. I am planning to use TPS61085 Boost converter in an battery (2.2~3.6)Volt energized device, and I need to have for a short time 18Volts output to supply 2 current output (4~20)mA sensors. To save energy of battery it is mandatory to isolate output load of converter from battery voltage, which is at the input of converter, during shutdown time. Can you recommend where to place PMOS FET - at the input of boost or at the output?
