BQ2060A low power mode - how to confirm?
Other Parts Discussed in Thread: BQ2060A
Is there a way to confirm (other than measuring stand by current) that the chip entered low power mode?
Thank you
  • Alex,
    Its a very old device and experts have retired or left the company. With modern gauges, you can do this by scoping the thermistor signal, which changes characteristics significantly when low power (sleep) mode is entered. I honestly don't know if that works on the bq2060A and I doubt we can determine it just from the data sheet. If it sounds like something you could use, we could check it out for you.
    Doug
  • Doug, thank you for your help. I meant how to verify that the pack is actually in sleep mode after sending the sleep command to a closed pack. We have no physical access to the production pack PCB; is there some kind of acknowlegement sent back from the chip after it went to sleep, or other indirect way to know by monitoring the SMBUS?
  • Alex,
    The method Doug mentioned is really the only way to check if the device is in sleep mode on a sealed pack. Unfortunately, there is no way to verify that the part went to sleep through SMBus, as any communication on the bus will immediately wake the device back up.
