We are trying to get a quick SOC without performing a learning cycle on these batteries. If we power on the device, perform the CFG Update of the Capacity, Energy, Termination voltage, and taper current. Then attach a fully charged battery pack, how long will it take before the system can report SOC?
I understand the SOC will be more accurate after a learning cycle with the pack, but we need to do this for a short demonstration and will perform this learning cycle at a later date.
I've seen in another post:
"charge the cells to full, rest for 2 hours, discharge to empty using c/7 rate, rest 5 hourss, charge to full, rest 2 hours and dishcarge to empty and rest 5 hours."
Charge to full - Ok
Rest -- Not sure what this means
Discharge -- Our rate is C/14 to C/28 is this ok?
Rest -- Again what does this mean
Charge to full -- ok
Discharge to empty --- This is the issue, we don't have 14-28 hours at this point.
Thanks!
