Other Parts Discussed in Thread: , TPS23755, TPS23758
I experience high levels of switching noise from my TPS23754 design. I have copied the TPS23754EVM-383 reference design and loaded both it and my own design with a 36R resistors for 4W power consumption at the 12V output.
I use an RF current monitor probe around the ethernet cable. My spectrum analyzer is able to give good relative measurements up to 40 MHz. Both boards show narrow-band noise at the primary switching frequency (242.65kHz ref design, 260.5kHz my board) and at multiple harmonics.
Please help me out with these questions:
- In your experience, will the TPS23754EVM-383 on its own pass FCC and CE certification for PoE devices consuming some 20W? If the TPS23754EVM-383 passes, I believe my design passes as well.
- What action should I take to reduce conducted switching noise? (Common-mode choke, snubbers, tuning LC decoupling, other action)
Borge
