I am looking for replacement part of PTB48510C. We saw this part is obsolete.
Please help to propose an alternate part that matches the specification of PTB48510C.
Please provide this information ASAP as we are looking at it urgently.
Hi Santhosh,
Unfortunately, we do not have an alternate part to recommend. All of our Isolated DC/DC Modules are obsolete. The best approach I could recommend would be going with a discrete solution.
Kind regards,
Alejandro
Hi Jimmy,
Thanks for the response. Yes isolated dual output is required.
Vin is 48VDC. Vout is Dual 15VDC. Maximum output current required is 2A.
PTB48510C met this requirement with good cross regulation. Enable pin would be required as well.
Please specify if you have part with similar specification that meet this need.
Please provide clarification ASAP as we need it urgently.
Thanks a lot.
Santhosh
Hi Santhosh,
As Alejandro had previously mentioned, there is no alternate part to recommend for your application.
Unfortunately for your application there is no available isolated power module that is recommended for current/future designs. As such, Alejandro recommended using a discrete solution to achieve your application.
Regards.
Jimmy
