Other Parts Discussed in Thread: TLV840
Hi, I am using the BQ25505 as a solar harvester along with a single secondary battery (VB_SEC) as my main power supply, and I have no primary battery attached (VB_PRI). I am currently having issues exiting the cold start mode upon connecting VB_SEC and the solar harvester. I have a 2 to 1 power mux with V_STOR and VB_SEC as the inputs and my system load as the output. I need this configuration to disable BQ25505 from charging VB_SEC at very low temperatures. My current configuration does not isolate the system load from either power source and I believe this is why it will not exit cold start. Are there any TI applications that execute a similar topology?
