From the application report "Loop Response Considerations in Peak Current Mode Buck Converter Design", the Gdi‘s expression from equation 2 simplified to equation 3, Gdi=Vin/s*L, the reason is "The internal loop compensation is designed so that the crossover frequency is much higher than the corner frequency, 1/(2π√LCO). For crossover frequency and higher frequency, Equation 2 can be simplified"as Equation 3. "
My question is i could not understand the simplification procedure well, as why we just care about the crossover frequency or higher frequency? Why the frequency range below crossover frequency is not important?
Thank you
