Other Parts Discussed in Thread: BQ78350-R1, BQ78350
I'm using BQ76940 with BQ78350-R1 for one og my projects.
One of the cells in battery stack is weak because of which undervoltage error is hitting. As per my understating, the DSG pin will be low in UV fault and the it will go high again only after fault/error is recovered.
But while the DSG FET is off, the CHG signal will not get its reference ground and the CHG fet will not turn on. What do I do to charge my battery once the UV fauly has occured?
