Other Parts Discussed in Thread: LP5012, USB2ANY
The installation and use of the last version of the software hadn't solved the issue.
(see https://e2e.ti.com/support/power-management/f/196/p/870845/3228404)
Best Regards
Best Regards
Hi Yannich,
Is your issue the same as this thread?
https://e2e.ti.com/support/power-management/f/196/p/885803/3276286#3276286
Hi, yes, it's the same issue, but I can't use the proposed solution (use I²C adress 0x14) with the last GUI version.
It says invalid adress or similar message and don't take the value 0x14.
Only 0x28 & 0x29 seem to be OK for the GUI (as mentionned in the GUI documentation) and both don't work with similar effect.
I captured I²C signals at the EVM board input (SDA & SCL signals). Maybe you can tell me if you see something is wrong (start condition seems not good implying a bad decoding of the adress by the LP5012 of the EVM; but I'm not sure about this...
For info, at bottom of the capture there is the picoscope I²C decoding using a threshold around 1.5V.
I tried 2 different USB2ANY and got similar signal traces...
Hi Yannick,
Making LP5012/09 address available to 0x14~0x17 is the reason why we built a new version GUI. Please help to check the GUI version in your computer by clicking Help --> About (New version is built at Dec 26 2018 while old one is Sep 03 2018). You could delete the GUI and install the new version again.
I attached new GUI E2E web below.
https://e2e.ti.com/support/power-management/f/196/t/855538?tisearch=e2e-sitesearch&keymatch=LP5012
