hii , i need a recommendation for an lithium ion battery pack charger IC, my BAT pack with voltage of 3.7 volts and capacity of around 3 up to 5 AH
i need at the same time to be able to charge my battery pack and drive a system from the battery pack through your charger IC .
my input voltage to the charger IC can be up to 6 volts
my system needs about up to 3 amps and operates with a voltage of 3.7
