Other Parts Discussed in Thread: EV2400, BQ24160
I have previously asked about this. I switched to BQ27441G1B before learning about the chem ID issues. I have attached my results of the chemid tool. We have a deadline approaching and although we have made a revision of a board with the BQ27520 we may not have the time to implement it. Can you let me know what the expected error we would get if we used our battery with the BQ27441. We have figured out that part of the problem we were having in the past is that although our battery is "removable" it is never actually removed so we weren't running battery insert initialization. We have since fixed this, but we still see some unexpected jumps if we power our system off (leaving the fuel gauge in standby) and boot it back up, we sometimes see a 10-20% jump after just being off for a couple minutes. Should we be saving certain RAM values to our MCU in case we do experience a power loss? If so what should we save? Do we need to do a golden image? If so what are the steps we would need to do to create a golden image? Would we have to program the golden image at the factory? Would we have to reprogram it if there is a power loss? I have the EV2400 and the eval kit for the BQ27441.cue battery-report (1) (1).zip
