Part Number: BQ25616
Hello
I am looking to bypass the thermistor circuit on the BQ25616 in that in my design there is both no way to get a thermistor in contact with the battery and also in that I will be charging using the lowest (safest) setting of the device. The documentation does not make it clear if and how to bypass this feature. Using other devices, it is commonly as simple as using a 10k resistor in place of the thermistor. Is it possible to do this?
Thank You
