Other Parts Discussed in Thread: TPS2596, TPS2595
Following on from a previous question raised on the support Forum "ISET PIN resistance setting range"
What is the impact if a resistor higher than 200k is used for RRSET?
I have tested with 247k on the bench and all is working well and as expected across many devices, so I haven't seen any negative impact but I want to understand if there are any limitations.
As a side note can you suggest an alternative device that has a lower quiescent current . TPS2421-1 has a TYP 3.9mA bias current when EN = 0. We are only interested in the current limit, and latch feature of the device.
Best Regards
Ian
