Is UCC24612 can be used for regenerative braking application where three phase sinusoidal back emf from motor is converted to DC which will recharge the battery.
Can I use this to get high efficiency during rectifier process?
The UCC24612 was designed for flyback and LLC converters. However, it may work for your application. I am not sure. This might be something you would consider evaluating in your lab.
The following link will get you the UCC24612 evaluation module which you can order and evaluate.
