TPS23755: Wurth solution for replacing LTD950-50r
Part Number: TPS23755
Other Parts Discussed in Thread: TPS23753A
I have a TPS23755EVM-894 based design.  Could anyone send me the Wurth solution?
The suggested replacemend i get from Wurth is 749119112.
Nico de Pender
  • Hi Nico,
    Thank you for your question.
    I will send you an E2E friend request momentarily. Please accept and I will share details about the recommended Wurth transformer to be used with the TPS23755 in private message.
    Thank you!
    Brett Colteaux
    PoE Product Marketing Engineer
  • The recommended Wurth transformer is a special product.
  • Hi Nico,
    The recommended Wurth transformer (and also the Linkcom transformer used on the EVM) was designed specifically for use with the TPS23755 in a primary side regulated (PSR) topology in order to take advantage of the benefits of this IC/topology combination. This includes removing the opto  + feedback circuitry from the feedback network in order to reduce the solution size and BOM.
    If you prefer to take the secondary side regulated approach and to use an off the shelf transformer (although this will require the opto + feedback network in your design), then I recommend using the TPS23753A. PMP8803 utilizes the TPS23753A in a 12V/Class 3 design and may be of interest to you.
    Please let me know if you have any other questions. Thanks!
    Brett Colteaux
