Other Parts Discussed in Thread: TPS3703,
Hello E2E,
When latch mode and MR-pin is open settings, please let me know that how to device reset.
At start up, RESET-pin of TPS3703 output Low, therefor it has to be High.
I will connect the DC/DC power-good signal(open drain, pull-up to 5V) to divided voltage resistors(10k & 10k) on CT-pin, RESET-pin output is masked until monitored power supply reach to normal voltage.
When the DC/DC PG gose to high, unlatch the TPS3703, unmaske RESET output.
Do you think this procedure is correct?
ACGUY
