TPS62748: Datasheet appears to have cut/paste errors
Part Number: TPS62748
Other Parts Discussed in Thread: TPS62743,
TPS62748 Datasheet Sections 7.3, 7.5, and 9.2.3 appear to have data related to TPS62743/TPS627431, not TPS62748.
Specifically, I would like a clarification as to what the IOUT line of the table in Section 7.3 should look like for TPS62748.
I should also mention that the TPS62743/TPS627431 datasheet also has confusing IOUT lines of the table in Section 7.3 (perhaps the first line is meant to be 62743 and the second is meant to be 627431?).
http://www.ti.com/lit/ds/symlink/tps62748.pdf
http://www.ti.com/lit/ds/symlink/tps62743.pdf
  • Hi John,
    I am working with my team to fix the issues. I will update you about the changes as soon as possible. Regarding the IOUT line in section 7.3, it should just be a typing error, but let me also cross check with my team internally.
    Thank you for your understanding!
    Febin
  • Hi John,
    I had a short discussion with my team regarding your question.
    IOUT line in section 7.3  for TPS62748 datasheet was just a typing error. The values remain the same. The other remarks are transferred to the responsible team and we will do the needful.
    I hope this clarifies your question and hence I would like to close this post now. Please feel free to re-open if necessary.
    Febin
