Other Parts Discussed in Thread: TLC59116
Dear Team,
Do we have LED driver to promote which is similar to MBIA045?
MBIA045 is designed for LED video applications using internal Pulse Width Modulation (PWM) control with selectable 16/10-bit color depth which features a 16/10-bit shift register which converts serial input data into each pixel gray scale of output port. The output current can be preset through an external resistor. Moreover, the preset current of MBIA045 can be further programmed to 64 gain steps for LED global brightness adjustment.
ItemsSpec.Content
01Protection - Over Current
02No. of Output Channel16
03Output Current per Channel1~45mA
04Sustaining Output Voltage17V
05Excellent Output Current Accuracy-between channels<±2.0% (typ.)
06ExcellentOutput Current Accuracy-between ICs<±2.5% (typ.)
07Embedded MOSFET
08Supply Voltage3.3V~5V
09Transmission Interface-SPI W/Daisty Chain
10Control InterfaceProprietary SPI-Like
11Scan Design
12LED Matrix Configuration
13Error Detection - LED Open
14Error Detection - LED Short
15Error Detection - LED Pixel Short
16Current Gain6-bit
17Intelligent Power Saving
18PWM16/10-bit
19I/O LevelVDD
20EMI Noise ReductionChannel output Shift、PWM Forward/Backward Counting
217 Challenges - Ghosting Elimination
22Protection - Thermal Shutdown
23RoHS Compliant PackageSSOP24
QFN24
