It appears that Figure 1 of the datasheet has the orientation of the MOSFET backwards. It has the drain at ground and the source at the negative battery terminal. As I understand it, this chip performs overvoltge protection during charging. If that's the case, then when the MOSFET is off, conventional current would continue to flow out of the negative terminal throught the body diode to ground, and there would be no protection. But perhaps I misunderstand what this chip is supposed to do. Could I get some clarification on this?
